[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Docker install of PAS 12.1 fails with segmentation fault
  • Thread starter Thread starter bronco
B
bronco
Dockerfile: FROM adoptopenjdk/openjdk8 LABEL maintainer="Bronco Oostermeyer (dev@bfv.io)" RUN \ mkdir /install && \ mkdir /install/openedge # ADD OpenJDK8U-jdk_x64_linux_hotspot_8u242b08.tar.gz /opt/java/openjdk/ ENV PATH=$PATH:/opt/java/openjdk/bin ADD PROGRESS_OE_12.1_LNX_64.tar.gz /install/openedge # you need a response.ini from a previous install COPY response.ini /install/openedge/response.ini ENV TERM xterm RUN /install/openedge/proinst -b /install/openedge/response.ini -l /install/install_oe.log RUN rm -rf /install/openedge && \ rm -f /usr/dlc/progress.cfg RUN groupadd -g 1000 pasadmin && \ useradd -r -u 1000 -g pasadmin pasadmin ENV DLC=/usr/dlc ENV WRKDIR=/usr/wrk ENV PATH=$DLC:$DLC/bin:$PATH # create directories and files as root RUN \ mkdir /app/ && \ mkdir /app/pas/ && \ mkdir /app/license/ COPY start.sh /app/pas COPY dummy.log /app/pas # turn them over to user pasadmin RUN chown -R pasadmin:pasadmin /app/ RUN chmod +x /app/pas/start.sh ENV PROCFG=/app/license/progress.cfg USER pasadmin VOLUME /app/license
