C
cjbrandt
I don't think so, but it has been too long since I worked on 9.1D to remember, what idxbuild could do then. If this is concerning the D&L, I would just include the "bulid indexes" phrase with the proutil load command for all tables and avoid running the idxbuild. If I recall correctly, you want to either use build indexes for every table, or for none of the tables, because the idxbuild command will scan through the entire database with a single thread when you run it. That takes a large amount of time.
