Sanjeev Reddy
Hi, PDS OE shows only development server instances in servers view and from the pose I can see that, you are also trying to add development servers to the servers view. If Create Servers & Finish not creating PAS development servers from remote OpenEdge Explorer configuration, then please try to following steps to add the server: Go to Servers view and then right click on servers view and select New > Server Select “Progress Application Server for OpenEdge” entry in New Server wizard and click Next Select the Explorer connection from which you want to create a server and then “refresh” icon adjacent to “Progress Application Server for OpenEdge” This will list all the available server instances, select the one you want and click Finish. If you see any errors after step3, please post it here. So, that we can take a look and see what’s the issue is. Hope this helps, Sanjeev
