P
Patrick Tingen
For work on windows / dialogs I still use the AppBuilder. I find it much more convienient than Eclipse for these things. When I try to add a trigger to a widget (11.6), I right-click the widget, select 'Add Trigger' and then Eclipse switches to code view. And then nothing happens. I expected some kind of dialog to specify what trigger I would like to add, but the code comes into view and that's it. In the code, I can should be able to add a trigger using ALT+SHIFT+G but that also does nothing. Looks like a bug...
