Sanjeev Reddy
Hi Brian, I would like to add some information regarding list of servers in servers view. PDS OE requires both Admin Server and Fathom are up and running to list the servers. Below are the different possible scenarios: Assuming Admin Server and Fathom are up and running before launching PDS OE: In existing workspace, PDS OE lists all the servers which are listed earlier at time of creating new workspace. If you want to update the servers list, go to Window > Preferences > Progress OpenEdge > Server > OpenEdge Explorer Connections and then “Edit Connection Profile” and then click “Create Servers & Finish”. It’ll refresh the servers view with latest available servers from OpenEdge Explorer In new workspace, PDS OE fetches all the servers from OpenEdge Explorer after launching workspace and then list the latest available servers from OpenEdge Explorer in Servers view Assuming Admin Server and Fathom are not up and running before launching PDS OE: In existing workspace, PDS OE lists all the servers which are listed earlier at time of creating new workspace. If you want to update the servers list first needs to start Admin Server and once it is up, go to Window > Preferences > Progress OpenEdge > Server > OpenEdge Explorer Connections and then “Edit Connection Profile” and then click “Create Servers & Finish”. It’ll refresh the servers view with latest available servers from OpenEdge Explorer In new workspace, first needs to start Admin Server from outside and then go to Window > Preferences > Progress OpenEdge > Server > OpenEdge Explorer Connections and then “Edit Connection Profile” and then click “Create Servers & Finish”. It’ll refresh the servers view with latest available servers from OpenEdge Explore. I think in your case, you didn’t click on “Create Servers & Finish” button to add the server in the Servers view. PDS OE actually doesn’t create any server, it just creates a launch configuration for that particular server. You can create a new server from servers view’s context menu options (New > Server > Expand Progress Software Corporation > Select Progress Application Server for OpenEdge > Next > Click Refresh button > Select Progress Application Server for OpenEdge and Click Finish. This will create a new server under Servers view. Once a new server is created, that configuration will stay in the workspace until we removed manually. Hope this helps, Sanjeev
