[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Develop the Barcode solution for QAD
O
OctavioOlguin
I depends which terminal is running your client. Is it linux chui? is it windows gui? is it something else? It depends. For instance, if you are using client networking on windows, just plug the scanner to the PC and start reading barcodes... It also depends on scanner. Some scaners are pre-configured to just send the barcode to the client and nothing else. Most of the cases you should configure the scanner to send a RETURN code just after the value that was read by the laser (or whatever technology is the scanner using). Yes, you should provide much more info on your configuration to get some reommendations.
