Anverion
Thanks for your response. Yes, I added the necessary property information for the service connector. It's like it just ignores that part of the workflow and then moves on the next. No error, no warnings. It just bypasses that part and moves on down the line. Unfortunately, I cannot modify the DDL of the table so I cannot add a logical delete flag. That would probably make things a bit easier. You mentioned adding EDC. Do you mean have both ADC and EDC enabled in the same vocabulary? Wouldn't that cause continuity issues on the Entities? I was under the assumption that ADC had the same functionality as EDC just with enhanced custom SQL capabilities. I have not seen anywhere in the documentation when they have enabled both. I would be interested if you knew where I could find this information. Thanks, Branden
