Anverion
Then I guess I'm missing something. I cannot delete records from he database. I am using ADC, I have pulled in the records that I want to delete, then, in the next rulesheet, I am checking a condition and then issuing a remove directive on the Entity. I would assume this would remove the data from the database. Is there something in ADC (not unlike EDC) where you can switch between read-only and read/write? Here's my workflow: and (the errors are at the bottom, need these removed from the database) and All this does is remove the 4 error rows from the output in the ruletest. The details in the database go unchanged. Also, I noticed that when I try to deploy this to the server, the Database mode = none and the Entity (all incoming) instead of "only new" is selected. They cannot be changed. I was able top change these settings using EDC. In ADC I cannot. Thanks, Branden
