jread
You will need to register you clientside script to attach to the load event of the page editor. The belowJS file is what Siteifnity uses to attached to the 'page load' OnDetailViewLoaded(). Once that script loads and attaches you should be able to modify the UI behavior // called by the DetailFormView when it is loaded function OnDetailViewLoaded(sender, args) { // the sender here is DetailFormView var currentForm = sender; Sys.Application.add_init(function () { $create(Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension, { _detailFormView: currentForm }, {}, {}, null); }); } Type.registerNamespace("Telerik.Sitefinity.Modules.Pages.Web.UI"); Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension = function () { Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension.initializeBase(this); this._detailFormView = {}; this._binder = null; this._emptyGuid = "00000000-0000-0000-0000-000000000000"; this._dataItem = null; this._translationSyncedWarningDialog = null; this._onDataBindDelegate = null; this._formCreatedDelegate = null; this._formClosingDelegate = null; this._continueToEditPageDelegate = null; this._copyLanguageChangedDelegate = null; this._isNewLanguageVersion = false; } Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension.prototype = { initialize: function () { Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension.callBaseMethod(this, "initialize"); this._binder = this._detailFormView.get_binder(); if (this._detailFormView) { this._formCreatedDelegate = Function.createDelegate(this, this._formCreatedHandler); this._detailFormView.add_formCreated(this._formCreatedDelegate); this._formClosingDelegate = Function.createDelegate(this, this._formClosingHandler); this._detailFormView.add_formClosing(this._formClosingDelegate); this._translationSyncedWarningDialog = this._detailFormView.getPromptDialogByName("translationSyncedWarningDialog"); } }, dispose: function () { if (this._onDataBindDelegate) { if (this._detailFormView) { this._detailFormView.remove_onDataBind(this._onDataBindDelegate); } delete this._onDataBindDelegate; } if (this._formCreatedDelegate) { if (this._detailFormView) { this._detailFormView.remove_formCreated(this._formCreatedDelegate); } delete this._formCreatedDelegate; } if (this._formClosingDelegate) { if (this._detailFormView) { this._detailFormView.remove_formCreated(this._formClosingDelegate); } delete this._formClosingDelegate; } if (this._continueToEditPageDelegate) { delete this._continueToEditPageDelegate; } Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension.callBaseMethod(this, "dispose"); }, _formCreatedHandler: function (sender, args) { var dataItem = this._binder.get_dataItem(); this._dataItem = dataItem; var detailFormView = this._detailFormView; //This is needed because the binder dataItem is sometimes changed after that (on dataBind) and we need to preserve the source object and language if (!this._onDataBindDelegate) { this._onDataBindDelegate = Function.createDelegate(this, this._onDataBindHandler); detailFormView.add_onDataBind(this._onDataBindDelegate); } var commandArgument = args.get_commandArgument(); if (!args.get_isNew() && args.get_commandName() == "edit") { this._toggleSectionByName("CopyLanguageSection", true); } else { if (commandArgument && commandArgument.language && commandArgument.sourceObjectId != this._guidEmpty) { dataItem.Language = commandArgument.language; dataItem.SourceLanguagePageId = commandArgument.sourceObjectId; var hideReturnToPages = commandArgument.isFromEditor; this._binder.set_uiCulture(dataItem.Language); this._toggleSectionByName("TemplateSection", true); this._toggleSectionByName("CopyLanguageSection", false); this._toggleWidgetByName("CreateAndReturnWidgetElement", hideReturnToPages); this._isNewLanguageVersion = true; var copyLanguageField = this._getFieldControlByDataFieldName("AvailableLanguages"); dataItem.SourceLanguage = this._detailFormView._defaultLanguage; copyLanguageField.set_selectedLanguage(this._detailFormView._defaultLanguage, false); if (!this._copyLanguageChangedDelegate) { this._copyLanguageChangedDelegate = Function.createDelegate(this, this._copyLanguageChanged); copyLanguageField.add_valueChanged(this._copyLanguageChangedDelegate); } } else { this._toggleSectionByName("TemplateSection", false); this._toggleSectionByName("CopyLanguageSection", true); if (args.get_commandName() == "duplicate") { // Do not allow the user to change the framework on duplicate. this._toggleFrameworkOptions(true); } //Set language for the template selector if (commandArgument && commandArgument.language) { var templateSelectorField = this._getFieldControlByDataFieldName("Template"); templateSelectorField.set_language(commandArgument.language); } } } }, _toggleFrameworkOptions: function (bDisable) { var frameworkField = this._getFieldControlByDataFieldName("Framework"); if (frameworkField) jQuery("input", frameworkField.get_choiceElement()).prop('disabled', bDisable); }, _copyLanguageChanged: function (elm) { this._binder.get_dataItem().SourceLanguage = elm.get_value(); }, _onDataBindHandler: function (sender, dataItem) { dataItem.Item.Language = this._dataItem.Language; dataItem.Item.SourceLanguagePageId = this._dataItem.SourceLanguagePageId; var copyLanguageField = this._getFieldControlByDataFieldName("AvailableLanguages"); if (copyLanguageField) { dataItem.Item.SourceLanguage = this._detailFormView._defaultLanguage; copyLanguageField.set_selectedLanguage(this._detailFormView._defaultLanguage, false); } }, _formClosingHandler: function (sender, args) { var form = sender; var commandArgument = args.get_commandArgument(); var isNew = args.get_isNew(); if (form.get_isMultilingual() && commandArgument) { isNew = commandArgument.languageMode == "create"; } if (isNew && args.get_isDirty()) { var widgetCommandName = form.get_widgetCommandName(); if (widgetCommandName == form.get_createCommandName() && this._isNewLanguageVersion == true) { this._continueToEditPageDelegate = Function.createDelegate(this, this._continueToEditPage); this._translationSyncedWarningDialog.show_prompt('', '', this._continueToEditPageDelegate, { dataItem: args.get_dataItem(), context: form }); } else { dialogBase.closeCreated(args.get_dataItem(), form); } args.set_cancel(true); } }, _continueToEditPage: function (sender, args) { var dataItem = args.get_commandArgument().dataItem; var context = args.get_commandArgument().context; var cancelEdit = args.get_commandName() == 'cancel'; if (cancelEdit) { dialogBase.closeCreated(dataItem, null); } else { dialogBase.closeCreated(dataItem, context); } }, _getWidgetByName: function (name) { var widget; var widgetBarIdsCount = this._detailFormView.get_widgetBarIds().length; while (widgetBarIdsCount--) { var widgetBarId = this._detailFormView.get_widgetBarIds()[widgetBarIdsCount]; var widgetBar = $find(widgetBarId); if (widgetBar) { widget = widgetBar.getWidgetByName(name); break; } } return widget; }, _getFieldControlByDataFieldName: function (dataFieldName) { return this._binder.getFieldControlByDataFieldName(dataFieldName); }, _toggleSectionByName: function (name, hide) { var sectionIds = this._detailFormView.get_sectionIds(); var sectionCount = sectionIds.length; for (var sectionIndex = 0; sectionIndex < sectionCount; sectionIndex++) { var sectionId = sectionIds[sectionIndex]; var section = $find(sectionId); if (section.get_name() == name) { var sectionElm = jQuery(section.get_element()); if (hide) { sectionElm.hide(); } else { sectionElm.show(); } break; } } }, _toggleWidgetByName: function (name, hide) { var widget = this._getWidgetByName(name); if (widget) { if (hide) { jQuery(widget.get_element()).hide(); } else { jQuery(widget.get_element()).show(); } } } } Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension.registerClass("Telerik.Sitefinity.Modules.Pages.Web.UI.DetailFormViewExtension", Sys.Component, Sys.IDisposable);
