[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Convert SQL RowId to OpenEdge ROWID
Did you find these links? community.progress.com/.../58016 knowledgebase.progress.com/.../unexpected-and-illogical-case-sensitivity-in-to-rowid It sounds like you are running into something similar. I ran into this while using the CLR bridge (ODBC interface) to execute and retrieve data via SQL queries into an ABL session. It is actually very fast, and allows us to build on the power of the sql92 engine.
