[progress Communities] [progress Openedge Abl] Forum Post: Re: Connection Between Tenant
  • Thread starter Thread starter Santosh Patel
Santosh Patel
Tenants in Rollbase are truly separate including their data. The one user multiple tenants option that Raj mentioned allows a user to switch between tenants but the data and apps are still very much disjoint. There is an option but it depends on to what extent you want the two tenants interlaced. You can have you data in D2C (Data Direct Cloud) and both your tenants can share the same data source. The apps installed in both tenants will be same. Hence, the data/objects backed by the common data source will show the same data in both tenants while regular objects (System and user created) of Rollbase will have their data compartmentalized per tenant. We are also planning to provide a generic JDBC connector which will let Rollbase connect to any data source in an adhoc manner which could be used in a similar manner.
