[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: $components
E
egarcia
Hello Greg, I do not think that we mention it in the documentation. You can find the reference this.$components in the controller.js file of a view created using the blank template. All the UI components used in a custom view are added to the this reference, Example: github.com/.../controller.js You can use this.$component from the controller.public.js file to access the options of the components and any property/method of them. Example: github.com/.../controller.public.js Please let me know if you need additional information. I hope this helps.
