[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Changing PASOE configuration dynamically (follow-up question about changing logging lev
I have another update from Progress tech support about the "dynamic" updates to logging configuration in PASOE. This information can be found in the KB: Progress KB - Unable to dynamically update the Pacific AppServer agents configuration Apparently the dynamic updates will be fixed once again after we upgrade to OE 11.7.6. In the meantime there is a workaround that involves a new property called " defrdlogentrytypes ". Even though Irfan has told us we cannot use that "deferred logging" feature in 11.7.5, we can in the very least set the property to the empty value in order to get our "dynamic" updates working again as before. Here is the excerpt from the KB. For OpenEdge 11.7.5 please follow the steps: 1. Add the property defrdlogentrytypes= in the "AppServer.SessMgr". Note: the property has empty value. 2. Restart the OpenEdge PAS instance for the changes to the Agents configuration to take effect. 3. Check if the functionality allowRuntimeUpdates works as expected. Hope this is clear. I'm extremely happy to have my dynamic logging back again. Note that sometimes you have to kill an individual _mproapsv to get it to "see" that logging configuration has changed... but at least you don't have to restart the entire PASOE instance!
