[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Changing PASOE configuration dynamically (follow-up question about changing logging lev
OK, I've reported it. Thanks for confirming. It would be nice if "allowRuntimeUpdates" was less ambiguous. I take it to mean that PASOE will allow me to change logging on the fly. But others may use it for purposes that I'm not aware of. It would be interesting to know what exactly can be dynamically changed without restarting the PASOE instance. Even in versions of OE when "allowRuntimeUpdates" worked, I believe that it wouldn't always take effect unless agent processes were restarted. (But at least that is better than restarting the entire PASOE instance.)
