[progress Communities] [progress Openedge Abl] Forum Post: Re: Binary Dump And Load, Apply...
  • Thread starter Thread starter gus
gus
> On Mar 3, 2016, at 10:06 AM, eswarm wrote: > > Yes I share the same experience, but thought of checking if someone has tried breaking algorithm behind mismatch counters and keys :-) doing that will not help. the counters are there for a reason. when a block's counters don't match the counter in the ai note, nearly always the data in the block will not match either. ignoring the mismatched counters when a note that says "replace the 23 bytes at block offset 581 with these other 48 bytes in area 12, block 651" is applied will result in corruption and maybe a crash if the contents of the data block is not in the expected state. other notes could cause knots in linked lists.
