O
OctavioOlguin
Anyway... removing the DECIMAL() on the fields solved this, after making shure on db that decimals is set to 6, instead a '?' that showed on datadict. Recompiled and rerun to avail... yes. The problem is that DECIMAL() was introduced last hour... but previous 5 hours, it behavied different... Datadictionary was created from XSD with bproxsdto4gl, and data definitions goes as: FIELD cdSubTotal AS DECIMAL DECIMALS 6 FORMAT "->>,>>9.999999" LABEL "cdSubTotal" COLUMN-LABEL "cdSubTotal" FIELD cdTotal AS DECIMAL DECIMALS 6 FORMAT "->>,>>9.999999" LABEL "cdTotal" COLUMN-LABEL "cdTotal"
