[progress Communities] [progress Openedge Abl] Forum Post: Re: Automation Toolkit Appsolute...
  • Thread starter Thread starter Thomas Hansen
Thomas Hansen
Can you paste the contents of the script you are using? You will very likely need to ensure that the client session also has the correct PROPATH set. This will depend on your settings in the config json file. The more detail you can provide the better ;-)
