W
whenshaw
I think that using oeablSecurity-basic-oerealm.xml would work. Be sure to change the authenticationModel setting in your JavaScript code to authenticationModel: progress.data.Session.AUTH_TYPE_BASIC I think that using the FCS of 11.5 would also work, but I am not sure about 11.5.1. If these don't work (or even if they do work), we can still try to find you a workaround for Form authentication in 11.6. Send me your oeablSecurity....xml file and I will take a look at it. You can send it directly to me at: whenshaw@progress.com
