Mukesh Singh
Hi Simi, We will look into the specific use case that has issue in 11.7.3(hope you have shared the reproducible use case & environment with TSE). As a workaround, you can try appending QUERY-TUNING(NO-JOIN-BY-SQLDB) to the affected query and compile the code that will disable 11.7.3 compiler feature and evaluate the join query at client side(same behavior like pre 11.7.3). Thanks, Mukesh
