[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: ABL Window does not regain focus after embedded OCX browse gains and loses focus.
  • Thread starter Thread starter Patrick Tingen
P
Patrick Tingen
A little bit of guesswork here, but you could try to place a button outside of the ocx. In the choose-trigger place some code to disable the ocx. After that, try the CTRL-F again. Is your application responding now? If yes, then you should think of a way to automatically disable the ocx when the user leaves it (or when the user re-enters the frame). Second option is to re-think the layout of the window. Of course I don't know it, but would it be an option to separate the ocx-part into its own pop-out window? If the user then decides to leave it, you could close that window and the problem would be gone as well.
