[progress Communities] [progress Openedge Abl] Forum Post: Re: Abl Unit Test 11.6 -...
  • Thread starter Thread starter DivyaTheja
DivyaTheja
If you are using PDS OE to run ABLUnit tests, results will be generated under working directory mentioned in PDS OE's ABLUnit run configuration. Changing working directory to other might help. If you are running from command-line, you can use outputdir parameter to generated results in custom location.
