Stefan Drissen
While cool, how safe is the environment? The session is started with a keyword forget list that contains: OS-APPEND OS-COMMAND OS-COPY OS-CREATE-DIR OS-DELETE OS-RENAME DOS UNIX THROUGH Using INPUT FROM OS-DIR a lot of the server can be explored. The server is running Debian GNU/Linux 8. Progress is installed in /usr/dlc. progress.cfg can be read. COPY-LOB can be used to overwrite files - my target being the /usr/dlc/version file. There is some sharing going on - so some of my sessions are seeing an adjusted version while others are not.
