[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: A valid class instance or static class name is required for dynamically invoking a meth
  • Thread starter Thread starter Laura Stern
L
Laura Stern
It clearly sounds like you are getting the wrong error message, so that is probably a bug. But the question is: why are you getting an error? Is the class in a package? When you moved the class into your work project, did you maintain the same directory structure? Are you running from r-code?
