V
Vimalkumar Selvaraj
Hi Iram, For your first issue did you create card by using our default design or created your own card?.. From error i could assume there might be a problem with your card template. Could you get the template HTML from card editor (source view) and place it here so that we can check if something wrong with your template?. One suggestion is we improved Card Editor and added support for desktop cards as well in latest version. I recommend you to try card creation with latest version and provide your suggestion. For your second issue we are looking into it and will update you soon.. Thanks, Vimal.
