[progress Communities] [progress Openedge Abl] Forum Post: Protrace From Using .net Regex...
  • Thread starter Thread starter christian.bryan@capita.co
C
(Please visit the site to view this file) HI All We have a webspeed app that uses the .NET regex class and causes intermittent protrace errors and crashes the webspeed agent. It also seems to coincide with other com object issues with excel and msxml 6.0. I have attached the source code and an example protrace file. The issues is in LIVE production environment with OE 11.3.3 and SQL Server dataserver. Protrace >>>>>>>>>>>>>>>>>>>>>>>>>>>>> ===================================================== PROGRESS stack trace as of Wed Sep 14 15:27:15 2016 ===================================================== Progress OpenEdge Release 11.3 build 1461 SP03 on WINNT Startup parameters: -pf C:\Progress\OpenEdge\startup.pf,-cpinternal ISO8859-1,-cpstream ISO8859-1,-cpcoll Basic,-cpcase Basic,-d dmy,-numsep 44,-numdec 46,(end .pf),-web,-logginglevel 2,-logfile C:\OpenEdge\WRK\OPENAccess-Live.server.log,-ubpid 12172,-wtbhostname 10.71.4.176,-wtbport 61897,-wtaminport 3202,-wtamaxport 3502,-wtbname OPENAccess-Live,-wtainstance 7,-ubpropfile C:\Progress\OpenEdge\properties\ubroker.properties,-logname OPENAccess-Live,-logthreshold 0,-numlogfiles 3,-logentrytypes DB.Connects,-ipver IPv4,-pf \\SDSDC02\OPENAssets\Params\Live\webstartup.pf,-db \\SDSDC02\OPENAssets\Code\live\SH\ihsh,-RO,-trig trig,-db oa_live,-ld ih,-dt MSS,-Dsrv PRGRS_NATIVE_LOCKWAIT,50,skip_schema_check,qt_cache_size,50000,prgrs_prepcache,500,-db \\SDSDC02\OPENAssets\Code\live\SH\faultlogssh,-RO,-trig trig,-db oa_live_faultlogs,-ld faultlogs,-dt MSS,-Dsrv PRGRS_NATIVE_LOCKWAIT,50,skip_schema_check,qt_cache_size,50000,prgrs_prepcache,500,-assemblies \\SDSDC02\OPENAssets\Code\live\ihlive\assemblies,-preloadCLR,-d dmy,-yy 1950,-rand 2,-s 500,-D 500,-IOEverywhere 1,-noincrwarn,-Bt 4000,-tmpbsize 8,-mmax 40000,-Mm 350,-dslog C:\OpenEdge\WRK\Logs\Live\datasrv.lg,-T C:\OpenEdge\WRK,-rereadnolock,-q,-cpinternal UTF-8,-cpstream UTF-8,(end .pf),-p webstartup.p,-weblogerror Exception code: E0434352 Fault address: 77114878 01:00013878 C:\Windows\SYSTEM32\KERNELBASE.dll Registers: EAX:00B9DE20 EBX:00000005 ECX:00000005 EDX:00000000 ESI:00B9DEE4 EDI:00000001 CS:EIP:0023:77114878 SS:ESP:002B:00B9DE20 EBP:00B9DE7C DS:002B ES:002B FS:0053 GS:002B Flags:00200212 Debugging dll: C:\Progress\OpenEdge\bin\DBGHELP.DLL Symbol Path: C:\Progress\OpenEdge\bin;C:\Progress\OpenEdge\pdbfiles Call Stack: Address Frame 77114878 00B9DE7C RaiseException+48 6CC206F2 00B9DF18 GetCLRFunction+1AF3D 6CE337FF 00B9DF4C CreateHistoryReader+15204 6CE48F82 00B9DFDC CreateHistoryReader+2A987 6E23B8BD 00B9DFEC 0001:0000A8BD C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E2476E4 00B9E71C 0001:000166E4 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E23825E 00B9E79C 0001:0000725E C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E238453 00B9E7B4 0001:00007453 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E2384C4 00B9E7D0 0001:000074C4 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E23C3BC 00B9E808 0001:0000B3BC C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E23C819 00B9E880 0001:0000B819 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E23BEE4 00B9E978 0001:0000AEE4 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6E2311B7 00B9E99C 0001:000001B7 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll 6CC6479F 00B9E9F0 CoUninitializeEE+14093 6CC65A43 00B9EA30 CoUninitializeEE+15337 6CC65A88 00B9EA9C CoUninitializeEE+1537C 6CC653AA 00B9EE54 CoUninitializeEE+14C9E 6CC6567F 00B9EF38 CoUninitializeEE+14F73 6CC666E6 00B9EFB8 CoUninitializeEE+15FDA 6CC4EB4D 00B9F030 DllCanUnloadNowInternal+91D 6CB81851 00B9F060 0001:00000851 C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll 6CC4EB9E 00B9F088 DllCanUnloadNowInternal+96E 04139739 00B9F1A4 0000:00000000 0068C186 00B9F1B4 Progress::ClrBridge::ITypeManager::ITypeManager+26 00278F38 00B9F254 dbut_utclex+1B27D8 ** ABL Stack Trace ** --> pr-Validate json_validate_longitude.p at line 7736 (\\SDSDC02\OPENAssets\Code\Live\Updates\json_validate_longitude.r) json_validate_longitude.p at line 7724 (\\SDSDC02\OPENAssets\Code\Live\Updates\json_validate_longitude.r) run-web-object web/objects/stateaware.p at line 3806 (C:\Progress\OpenEdge\tty\web\objects\stateaware.r) run-web-object web/objects/web-util.p at line 4212 (C:\Progress\OpenEdge\tty\web\objects\web-util.r) SYSTEM-TRIGGER web/objects/web-disp.p at line 653 (C:\Progress\OpenEdge\tty\web\objects\web-disp.r) web/objects/web-disp.p at line 721 (C:\Progress\OpenEdge\tty\web\objects\web-disp.r) webstartup.p at line 705 (\\SDSDC02\OPENAssets\Code\Live\ihlive\OHWEB\wwwcos\webstartup.r) ** Persistent procedures/Classes ** Handle File Name 045664 \\SDSDC02\OPENAssets\Code\Live\Updates\json_validate_longitude.r 013416 \\SDSDC02\OPENAssets\Code\Live\ihlive\LoggerActive.r 000000 \\SDSDC02\OPENAssets\Code\Live\ihlive\LogManager.r (STATIC) 013408 \\SDSDC02\OPENAssets\Code\Live\ihlive\libRepairs.r 001260 \\SDSDC02\OPENAssets\Code\Live\ihlive\libgen.r 001229 \\SDSDC02\OPENAssets\Code\Live\Updates\sds_joballoc_manager.r 001034 C:\Progress\OpenEdge\tty\web2\admweb.r 001033 C:\Progress\OpenEdge\tty\web2\wbdata.r 001032 C:\Progress\OpenEdge\tty\web2\webrep.r 001030 C:\Progress\OpenEdge\tty\adm2\queryext.r 001029 C:\Progress\OpenEdge\tty\adm2\query.r 001026 C:\Progress\OpenEdge\tty\adm2\dataquery.r 001022 C:\Progress\OpenEdge\tty\adm2\smart.r 001019 C:\Progress\OpenEdge\tty\web\support\webmsg.r 001018 C:\Progress\OpenEdge\tty\web\support\tagrun.r 001017 C:\Progress\OpenEdge\tty\web\support\webedit.r 001016 C:\Progress\OpenEdge\tty\web\support\weblist.r 001015 C:\Progress\OpenEdge\tty\web\support\webradio.r 001014 C:\Progress\OpenEdge\tty\web\support\webtog.r 001013 C:\Progress\OpenEdge\tty\web\support\webinput.r 001012 C:\Progress\OpenEdge\tty\web\objects\session.r 001011 C:\Progress\OpenEdge\tty\web\objects\web-util.r 001010 C:\Progress\OpenEdge\tty\web\objects\stateaware.r 001009 C:\Progress\OpenEdge\tty\webutil\webstart.r 001008 \\SDSDC02\OPENAssets\Code\Live\ihlive\toolbar.r 001007 \\SDSDC02\OPENAssets\Code\Live\core\stdprocs.r 000000 \\SDSDC02\OPENAssets\Code\Live\ihlive\Consultingwerk\WidgetTypeEnum.r (STATIC) 000000 \\SDSDC02\OPENAssets\Code\Live\ihlive\Consultingwerk\Assertion\HandleAssert.r (STATIC) 000000 \\SDSDC02\OPENAssets\Code\Live\ihlive\SessionHelper.r (STATIC) 001000 \\SDSDC02\OPENAssets\Code\Live\core\stdproc.r ** PROPATH ** .,C:\Progress\OpenEdge\tty,C:\Progress\OpenEdge\tty\adecomm.pl,C:\Progress\OpenEdge\tty\adecomp.pl,C:\Progress\OpenEdge\tty\adeedit.pl,C:\Progress\OpenEdge\tty\adeshar.pl,C:\Progress\OpenEdge\tty\dataadmin.pl,C:\Progress\OpenEdge\tty\prodict.pl,C:\OpenEdge\WRK,\\SDSDC02\OPENAssets\Params\Live,\\SDSDC02\OPENAssets\Code\Live\Custom,\\SDSDC02\OPENAssets\Code\Live\Updates,\\SDSDC02\OPENAssets\Code\Live\ihlive,\\SDSDC02\OPENAssets\Code\Live\core,\\SDSDC02\OPENAssets\Code\Live\ihlive\OHWEB\wwwcos,\\SDSDC02\OPENAssets\Code\Live\ihlive\OHWEB\wwwcoh,\\SDSDC02\OPENAssets\Code\Live\os,\\SDSDC02\OPENAssets\Code\Live\workflow,C:\Progress\OpenEdge,C:\Progress\OpenEdge\bin ** Databases (logical/type/physical) ** ihsh PROGRESS \\SDSDC02\OPENAssets\Code\live\SH\ihsh ih MSS oa_live faultlogssh PROGRESS \\SDSDC02\OPENAssets\Code\live\SH\faultlogssh faultlogs MSS oa_live_faultlogs ** End of Protrace ** Any help appreciated. Thanks Christian.
