[progress Communities] [progress Openedge Abl] Forum Post: Problem To Generate Model (edmx)...
  • Thread starter Thread starter 012
012
Hi, I'm facing a problem during testing the ADO.Net provider for DB2 on Z/OS. I'm using Visual Studio 2012 and a trial of the ADO.Net provider 4.2 from Progress as you can see : On a new project, i'm trying to generate a model from the Database using EntityFramework but i have problems. Here is the steps I did : - Right-click on the fresh project - Add a new file - I select ADO.NET Entity Data Model and click to Add - Then i select "EF Designer from a database" - I create a new connection, and testing it works fine (bind packages are done etc.) - I include sensitive information on the ConnectionString and I clic on next and then... In english "Your project references the latest version of Entity Framework; however, an Entity Framework database provider compatible with this version could not be found for you data connection. Exit this wizard, install a compatible provider, and rebuild your project before performing this action" I have the same error installing EntityFramework 6.0.0, 6.0.2, 6.1.3 I tried to install EF 5.0 and I have this screen : In english "Your project references an older version of Entity Framework. To use the latest version, exit this wizard andupgrade before performing this action" Can you please help me to solve this ? I'm on this problem from days and now i have no idea to do.. I tried on x64, x86, Any CPU.. Thanks Regards
