[Progress Communities] [Progress OpenEdge ABL] Forum Post: Problem connecting via ODBC
  • Thread starter Thread starter James Palmer
James Palmer
I'm trying to set up ODBC connections on my databases. OE 10.2B08 Windows 2012 64bit server I've configured everything up as expected, but when you try and connect, even locally you get the following in the logs: [2017/12/05@15:17:11.569+0000] P-7328 T-7904 I FMAGENT13: (14262) Successfully connected to AdminServer on port 8842 using TCP/IP IPv4 address 192.168.101.28. [2017/12/05@15:17:11.570+0000] P-7328 T-7904 I FMAGENT13: (8846) Registered with Admin Server. [2017/12/05@15:18:28.174+0000] P-7352 T-528 I SQLSRV2 2: (-----) SQL Server 10.2B.08 started, configuration: "l_idx_cmo_pws.defaultconfiguration" [2017/12/05@15:18:28.179+0000] P-7352 T-528 I SQLSRV2 2: (-----) Failure during dsmUserSecureConnect (-1) [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) "odbcservergroup" started on IPv4 port 3000 for address 0.0.0.0, pid 7352 (0x00001cb8). [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) Thread stack size: 1024000 (bytes). [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) DLC from ENVIRONMENT VARIABLE is: C:\Progress\OpenEdge [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) WRKDIR from REGISTRY is: C:\OpenEdge\WRK\ [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) JDKHOME from REGISTRY is: C:\Progress\OpenEdge\jdk [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) JREHOME from REGISTRY is: C:\Progress\OpenEdge\jre [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) CLASSPATH from DEFAULT is: [2017/12/05@15:18:28.185+0000] P-7352 T-528 I SQLSRV2 2: (-----) PROSQL_LOCKWAIT_TIMEOUT value is: 5 seconds I read some knowledgebases to see it could be to do with permissions, so I've made sure the Admin Service is starting as the user that created the databases and also ensured that user has full rights to the database directory. Still the same. Does anyone have any ideas?
