jokilval
Hello, I'm having difficulties with installing the new 6.0 version of Pro2 to our testing environment with OpenEdge 11.7 on Windows server 2012 R2. When installing the Pro2 version 6.0 the installation completes with no errors. But some files are missing from the installation directory. When trying to open the administration tool, it says **”bprepl\bpAdmin.w” was not found. (293) and the Progress Window stays gray and can only be closed from task manager. It seems that the bpAdmin.w is really missing from the bprepl\ directory as well as some other .w files that I found in the previous (5.x) installations of Pro2. To my understanding the Pro2 6.0 should work with OpenEdge 11.7 and does not require 12.0. When installing the 6.0 version I followed the exact same steps as with the 5.x version. I also tried to uninstall and install Pro2 6.0 again with same results. Installation log files show no warnings or errors. Is there something different that need to be taken into account when installing version 6.0 compared to 5.x? Or what could I be missing here?
