[progress Communities] [progress Openedge Abl] Forum Post: Private Cloud Installation Problem
  • Thread starter Thread starter leonc
L
leonc
I am trying to install latest Rollbase 4.4 to Azure following the instructions in the user guide and to the document here . Server is a VM Windows 2012 R2 Datacenter and database Azure SQL Server. Installation with Rollbase installer on VM finished with no problems. Creation of necessary tables for Rollbase to SQL Server executed with no errors. Edited databases.xml , shared.properties and components.xml accordingly. In the localhost.log there is the following error: 02-Dec-2016 14:49:39.762 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.loadOnStartup Servlet [Starter] in web application [/master] threw load() exception com.microsoft.sqlserver.jdbc.SQLServerException: Violation of PRIMARY KEY constraint 'PK__RB_LIST___ADFD89A0BD248F03'. Cannot insert duplicate key in object 'dbo.RB_LIST_ITEM'. The duplicate key value is (-1). And when you try to login , you can't . A message appears on the login form saying: A constant expression was encountered in the ORDER BY list, position 1. Any ideas? Thank you in advance.
