DenDuze
Hi, In PDS you can define/configure a (Ant) Builder for a project (project - properties - Builders) This works fine but in my case i want the same Builder in all my OpenEdge projects. I tried with OpenEdge - Tools - Customization Editor but that did not work I define there that when I create a new Openedge project that a directory ".externalToolBuilders" needs to created under that project and a *.launch file (that Is the original file that was created by the system when i defined/configured such a (Ant)builder In another project) needs to be copied under that ".externalToolBuilders" directory. This works fine (directory and file are created under that new project) but when I go to the properties - builders of that new OpenEdge Project that (Ant) builder is not there. Isn't there some way in PDS where I can define that a custom builder needs to be added to the project when I create a new OepenEdge project? Regards Didier
