[Progress Communities] [Progress OpenEdge ABL] Forum Post: PCT ANT RCodeSelector issue
  • Thread starter Thread starter MBeynon
MBeynon
Hello, I'm having difficulty in getting this aspect of PCT working as I would expect. I have a PCT ANT build script which generates a library from an RCODE folder; build/rcode build/library when the script runs the rcode in the RCODE folder is copied and flattened (absolute paths removed) into a temp folder. build/rcode/temp It's from this temp folder that the library is built. My problem is that when the build script compares the new RCODE with the previous library, every file is reported as being a different MD5 and copied to my compare folder (see below). When I manually checked the md5 (RCODE-INFO:MD5-VALUE) of the library and rcode .r files they are the same! Thanks for any help, it's always much appreciated! :-) Mark.
