[Progress Communities] [Progress OpenEdge ABL] Forum Post: OpenEdge Management - Is there an easier way?
  • Thread starter Thread starter Jeff Ledbetter
Jeff Ledbetter
We have multiple versions of OpenEdge installed. Whenever a new version is installed, we have to remember to change the 'port' value in management.properties from something other than 6835 and then update the 'Remote AdminServer' in OEM. However, if you forget to change this port, OEM reads whatever is running on the default port of 6835. Okay. No problem. But once you change this value to say 6836, OEM has trouble "forgetting" the configuration that it read in from 6835 and you have to manually remove each invalid entry. Or, sometimes you cannot remove them at all because a null-pointer exception is thrown when trying to select one to remove. So, before we reinstall (again), is there a way to correct this?
