[progress Communities] [progress Openedge Abl] Forum Post: Openedge Explorer Issues After...
  • Thread starter Thread starter RJPowell
RJPowell
Afternoon, We've recently created an OE 11.6 version of our product, and are currently QAing the upgrade process from the existing 11.3 and 11.5 versions on a Windows 7 system. 11.5 to 11.6 has worked fine, but 11.3 to 11.6 is producing a wierd issue with OE Explorer. All we've done is uninstall the existing 11.3.1 installation, and installed 11.6 and SP1. Everything appears to be fine, the AdminService starts, firing up OE Explorer all looks good, you change the default password and it's all still fine, then after logging in with the new settings, you get this: We've rolled the system back and tried again a couple of times (initially we were using mergeprop to bring our 11.3 settings in, but we've tried without as well to rule that out), but it's always the same result. You can navigate around to other pages with the links at the bottom of the page (2nd screenshot), setup DBs and get them running, it's just all done with this messed up interface on every page. Anyone ever seen this or similar before?
