[progress Communities] [progress Openedge Abl] Forum Post: Oe Reference Arccitecture And...
  • Thread starter Thread starter MBeynon
MBeynon
Hello, I've been asked to investigate the OERA as a prelude to designing a new from the ground up web based system with typical CRUD functionality. As part of this process I've looked at the AutoEdge|The Factory as an example of an implementation of the OERA. I was wondering if anyone has found themselves in a similar situation. i.e Using OE116 and looking at developing a new system based on the OERA and if so what are; a. the pitfalls b. the caveats/provisos c. the benefits After downloading the sources and looking through the code the AutoEdge stuff looks very much like an OE version of something like a Java ORM framework such as Hibernate with the priciples of dependancy injection for example. So, basically, what I'm asking is if you were starting from scratch, what type of framework (if any) would you employ and why? Thanks.
