[Progress Communities] [Progress OpenEdge ABL] Forum Post: OE 12.1 Web UI application deploy to PASOE fails with default setup
  • Thread starter Thread starter george.ene
george.ene
Hi, Found an issue with deploy of openedge webui apps. Not sure if this is the place for such a post... maybe it will help some one else : If you create a new Web UI project in 12.1 and try to deploy it to PASOE the deploy will fail with error : "Context initialization failed org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: You cannot use a spring-security-2.0.xsd or spring-security-3.0.xsd or spring-security-3.1.xsd schema or spring-security-3.2.xsd schema or spring-security-4.0.xsd schema with Spring Security 4.2. Please update your schema declarations to the 4.2 schema". The error can be found in oemanager.log This is caused by the folowing values in webuiSecurity.xml (4 of them in each project) xsi:schemaLocation=" www.springframework.org/.../beans www.springframework.org/.../spring-beans-4.2.xsd www.springframework.org/.../security http://www.springframework.org/schema/security/spring-security-4.1.xsd"> To fix the error change the security version to 4.2 or the non version variant http://www.springframework.org/schema/security/spring-security.xsd .
