W
wvdgraaf
Using Progress version 11.7.4 PASOE I'm trying to follow the document "PAS for OpenEdge JWT and OAuth2 samples 2017-11-21.pdf", but I get an error in program idmActivate.p. In my logging I get the following lines: From idmStartup.p 09/11/2018 08:53:38,072+01:00 loaded domain JWTdomain 09/11/2018 08:53:38,077+01:00 loaded key 1a051b2c373c 09/11/2018 08:53:38,081+01:00 loaded domain Google 09/11/2018 08:53:38,085+01:00 loaded key 373d20203e20383629 09/11/2018 08:53:38,089+01:00 loaded domain AWSDomain 09/11/2018 08:53:38,093+01:00 loaded key 11051c2c373c 09/11/2018 08:53:38,259+01:00 loaded domain JWTdomain 09/11/2018 08:53:38,267+01:00 loaded key 1a051b2c373c 09/11/2018 08:53:38,279+01:00 loaded domain Google 09/11/2018 08:53:38,286+01:00 loaded key 373d20203e20383629 09/11/2018 08:53:38,294+01:00 loaded domain AWSDomain 09/11/2018 08:53:38,300+01:00 loaded key 11051c2c373c From idmActivate.p 09/11/2018 08:55:46,765+01:00 Required parameter for SET-CLIENT was passed the Unknown value. (15918) So when the agents start, the domains.json file is loaded. When I send the JWT token using Postman it gets validated by PASOE and should be available in the ClientPrincipal. /* Code snippet */ define variable hCP as handle no-undo. hCP = session:current-request-info:GetClientPrincipal(). lok = SECURITY-POLICY:SET-CLIENT(hCP). Variable hCP contains unknown value, so the SET-CLIENT(hCP) gives me the error message. Question: Why is hCP unknown?
