C
christian.bryan@capita.co.uk
Hi Please see below simple program which returns an error on the JSON-READ: Error status yes Error parsing JSON: expected bracket, but found brace. (15358) This seems odd as the JSON was created from a JSON-WRITE and is valid JSON as far as i can tell. ******************************************************************************************************************* BLOCK-LEVEL ON ERROR UNDO, THROW. DEFINE TEMP-TABLE tt-CustomUIMessages SERIALIZE-NAME "UIMessages" FIELD MessageNumber AS INTEGER FIELD MessageType AS CHARACTER /* Warning, Input, Textarea, Lookup (select), Radioset */ FIELD MessageLabel AS CHARACTER FIELD MessageValues AS CHARACTER FIELD MessageHelp AS CHARACTER FIELD MessageAnswer AS CHARACTER FIELD MessageError AS CHARACTER FIELD MessageRead AS LOGICAL INDEX idx-primary IS PRIMARY UNIQUE MessageNumber INDEX idx-answered MessageType MessageAnswer INDEX idx-read MessageType MessageRead. /* This table holds the Key / Value pairs for dropdowns / Value */ DEFINE TEMP-TABLE tt-CustomUIMessagesValues SERIALIZE-NAME "UIMessageValues" FIELD MessageNumber AS INTEGER SERIALIZE-HIDDEN FIELD MessageKey AS CHARACTER FIELD MessageValue AS CHARACTER INDEX idx-primary IS PRIMARY UNIQUE MessageNumber MessageKey. DEFINE DATASET UiMessages SERIALIZE-HIDDEN FOR tt-CustomUIMessages, tt-CustomUIMessagesValues DATA-RELATION UIMessageValue1 FOR tt-CustomUIMessages, tt-CustomUIMessagesValues RELATION-FIELDS(MessageNumber, MessageNumber) NESTED. CREATE tt-CustomUIMessages. ASSIGN tt-CustomUIMessages.MessageNumber = 1 tt-CustomUIMessages.MessageType = "Lookup" tt-CustomUIMessages.MessageLabel = "WHat is the capital of England". CREATE tt-CustomUIMessagesValues. ASSIGN tt-CustomUIMessagesValues.MessageNumber = 1 tt-CustomUIMessagesValues.MessageKey = "LON" tt-CustomUIMessagesValues.MessageValue = "London". CREATE tt-CustomUIMessagesValues. ASSIGN tt-CustomUIMessagesValues.MessageNumber = 1 tt-CustomUIMessagesValues.MessageKey = "LIV" tt-CustomUIMessagesValues.MessageValue = "LIverpool". DATASET UiMessages:WRITE-JSON("file", "C:\OpenEdge\WRK117_64\sample_json.txt",TRUE, ?) NO-ERROR. DATASET UiMessages:READ-JSON("file", "C:\OpenEdge\WRK117_64\sample_json.txt","Empty") NO-ERROR. OUTPUT TO "C:\OpenEdge\WRK117_64\sample_json.log". MESSAGE "Error status " ERROR-STATUS:ERROR ERROR-STATUS:GET-MESSAGE(1). OUTPUT CLOSE. FOR EACH tt-CustomUIMessages NO-LOCK: MESSAGE "Message Number: " tt-CustomUIMessages.MessageNumber. END.
