[progress Communities] [progress Openedge Abl] Forum Post: Is It Possible To Use...
  • Thread starter Thread starter dhubbuck
dhubbuck
Hi, We've played around with OpenEdge 11.6.3 and successfully used some web handlers to return some data into an Angular2 web application and also a Nativescript app. We now want to add some security to the services and have chosen forms_oerealm. This works fine for testing from a browser but I can't seem to get access to the response token/ jsessionid cookie within the javascript (typescript) code when using an http post request to the j_spring_security_check url. Is this because it's just part of the http response or should it come back as json data? The service is currently on a different domain to the Angular 2 app. We have used this method in the past (Angular 1.5) when the webapp was deployed on the same PAS as the services so could it be a CORS issue? Here's a sample of the login code. let headers = new Headers(); headers.append("Content-Type", "application/x-www-form-urlencoded"); headers.append("Cache-Control", "max-age=0"); let options = new RequestOptions({ headers: headers, withCredentials: true }); let data = JSON.stringify({ j_username: user.username, j_password: user.password }); return this.http.post( Config.apiUrl + "static/auth/j_spring_security_check", data, options ) .map(response => response.json()) ; Should this work within a Nativescript app or should we just use the jsdo for session management and login purposes? Any pointers in the right direction would be appreciated. Thanks
