ridingmac
i get an wp-load-file was not found(293) error when executing this code. wp-load-file is used in a SYSTEM-DIALOG and return the full path for the file including file name. I have confirmed this with an ALERT-BOX INPUT FROM wp-load-file CONVERT TARGET "UTF-8" SOURCE "UTF-8" NO-ECHO. REPEAT: CREATE PARAM_tt_nice_convention. IMPORT DELIMITER ",":U PARAM_tt_nice_convention. END. INPUT CLOSE. How ever if i replace wp-load-file with a hardcoded string pointing to the exact same path, it works files. INPUT FROM "C:\temp\excelFile.csv" CONVERT TARGET "UTF-8" SOURCE "UTF-8" NO-ECHO. REPEAT: CREATE PARAM_tt_nice_convention. IMPORT DELIMITER ",":U PARAM_tt_nice_convention. END. INPUT CLOSE. I have confirmed that wp-load-file give tha exact same path. Thanks in advance for the help.
