jbijker
We have a table called wft_activity_log with a non-unique index on process_log_obj and status_key. Now when I have the following code code and do a XREF compile (only checked under OE11.3): FIND FIRST wft_activity_log NO-LOCK WHERE (wft_activity_log.process_log_obj = 1 AND wft_activity_log.status_key = "Active") OR (wft_activity_log.process_log_obj = 1 AND wft_activity_log.status_key = "Busy"). FOR EACH wft_activity_log NO-LOCK WHERE (wft_activity_log.process_log_obj = 1 AND wft_activity_log.status_key = "Active") OR (wft_activity_log.process_log_obj = 1 AND wft_activity_log.status_key = "Busy"): DISPLAY wft_activity_log. END. The FIND FIRST surprisingly does a WHOLE-INDEX scan SEARCH mipdb.wft_activity_log xPK_wft_activity_log WHOLE-INDEX But the FOR EACH is using the correct index (2 times): SEARCH mipdb.wft_activity_log xIE1_wft_activity_log So it seems the FIND and FOR EACH doesn't follow the same rules? Anyone had the same behaviour before? And maybe an explanation of why the compiler does this?
