[Progress Communities] [Progress OpenEdge ABL] Forum Post: Execution of (java) TRIGGER failed in OE sql engine; Error Code -210154
  • Thread starter Thread starter Rom Elwell
Rom Elwell
EDIT : I have ensured the sql environment is setup, including stopping the DBs and running 'sql_env' from proenv. I have created a Java trigger that fires on Update of the Employee table. When I execute a simple Update statement in SquirrellSQL to test, the following error is returned. Error: [DataDirect][OpenEdge JDBC Driver][OpenEdge] Execution of TRIGGER, PUB.SQLEMPLOYEEUPDATE failed in OE sql engine at line Z:/vobs_sql/sql/src/sqlsp/cxx/DDMJavaCache.cxx : 958.(19152) SQLState: HY000 ErrorCode: -210154 Google-fu is failing me as I am unable to find any references to this message or the associated error code. I'm hoping someone here can shed some light on the matter for me. Thanks in advance!
