B
Blake Stanford
I have installed 2 pas instances on with the developer license on the same machine with no problems. When I try to duplicate the process on with a production license only one instance will start at a time. I get the following error from OEM: Failed to start pas instance Test: Exception parsing the response: Unexpected character (''"'' (code 34)): was expecting comma to separate Array entries at [Source: { "start-action": "start","initial-state": "stopped","initial-processes": "0","exit-state": "started","exit-description": "PASOE instance stopped during startup due to errors...","exit-processes": "0","exit-status": "4","exit-errors": ["/agility/progress/wrk/11.7/Test/logs/catalina.2017-12-13.log:13-Dec-2017 10:44:33.875 SEVERE [main] org.apache.catalina.core.StandardServer.await StandardServer.await: create[localhost:8005]:"",13-12-2017 10:46:30.00 ERROR [main] One or more multi-session Agent startup failures - see Agent logfiles"]}; line: 1, column: 431] Has anyone else had this situation?
