[progress Communities] [progress Openedge Abl] Forum Post: Error Running Roundtable 11.6 In...
  • Thread starter Thread starter Jeff Ledbetter
Jeff Ledbetter
Hi all. We recently discovered an issue that I wanted to bring to your attention along with the work-around. Entry Type K-Base Number: 282 Synopsis Roundtable TSMS Fails to Load 64-Bit DLL Resolution When running OE 64-bit client-server and the start-in directory is the Roundtable installation root, the rtbwin64.dll does not properly load when invoked. Instead, a Progress error 12272 is generated when the repository is accessed: "A variable or array element passed as an INPUT or INPUT-OUTPUT parameter to a DLL cannot contain the Unknown value. (12272)" However, turning on client-logging and digging in further, one will find that the DLL invocation is generating Progress error 3258: "Could not load DLL procedure . (3258)" A work-around is to ensure that the Roundtable short-cut start-in directory is a directory other then the Roundtable installation directory with the appsrvtt.d file moved to that directory. The root cause is known OpenEdge defect scheduled to be fixed in 11.7: knowledgebase.progress.com/.../Attempt-to-load-external-DLL-located-in-working-directory-fails-with-error-3258-with-a-64-bit-GUI-client
