[Progress Communities] [Progress OpenEdge ABL] Forum Post: Developer Studio / PAS Instances Confusion
  • Thread starter Thread starter brianlafertewk
B
brianlafertewk
Is there a way to get a Developer Studio Workspace to refresh the list of PASOE servers available in 11.7.2? I'm noticing that if I have a single PASOE instance created, when I create Workspace, go into 'Preferences->Progress OpenEdge->Servers->OpenEdge Explorer Connections', add the appropriate Explorer info, when I create a new 'OpenEdge Project' and select 'Server', 'PAS for OpenEdge', 'WEB' transport, on the 'Supported servers' I will see my single PASOE instance. Now, if I add a new PASOE instance (now having two listed), closing out the Workspace and re-opening, when I try and create another 'OpenEdge' project, the new PASOE instance isn't listed. I've restarted the Admin Server, the machine, etc, and the list never updates. Even if I remove all PASOE instances, the Workspace will not see the change and still thinks the PASOE instance that was there when the server list was first updated is there. If I now create a new Workspace, and go through the same steps, I see all PASOE instances that were available when the OpenEdge Explorer Connection was created. I have tried removing the OpenEdge Explorer Connection, but still, the Workspaces don't notice the PASOE instance changes. I'm assuming there is a "refresh" button, or some file I can remove to get the current instance list to appear.
