[progress Communities] [progress Openedge Abl] Forum Post: Default Port Numbers
  • Thread starter Thread starter bbrennan
B
bbrennan
Is there a comprehensive list of default port numbers used by a modern version of OE? I have looked through the 11.6 e-docs and see partial tables. The Kbase seems to have snippets as well. Ideally, I am looking for the service and the default ports used by the installer. The use case is getting a few version of OE running on the same computer. Each version will run independently including WSA, AppServer, TomCat, DB Servers, Fathom etc. using multiple OE11 versions and most likely at 10.2B in there for good measure. I want to document my setup and have reasonable choices for all of the conflicting default ports. I know I can dig it all up myself - just seeing if I can tag along on work that has already been completed. Bob
