[Progress Communities] [Progress OpenEdge ABL] Forum Post: Create DataSet/Buffers from xsd with read-xml
  • Thread starter Thread starter DenDuze
DenDuze
Hi, I have a xsd-file from our customer. With a read-xml statement i create a DataSet from that xsd-file. It looks like this works great, my Dataset is created, all buffers are created and all relations are created. But now i noticed that some data from a data xml-file (that should comply to that xsd) is not found in any of the created buffers? I know it's not easy to answer this with that information but lies the problem for this in the xsd (maybe something in there is not ok) or in Progress (read-xml statement). Are there some known problems with that read-xml icw xsd-file? Progress 11.7.1 Regards Didier
