[progress Communities] [progress Openedge Abl] Forum Post: Binary Dump And Load, Apply Roll...
  • Thread starter Thread starter eswarm
E
eswarm
The current size of our database is around 2TB. The current estimate for binary dump, load and re-building index is around 25 hours (using 32 cores). Our application is 24/7/365, so bring it down for 25 hours will be a great challenge for me to sell to our stakeholders. Alternatively, there are some options which I could consider at Business level which will help to minimise the downtime of the application. However, I was thinking whether it is possible to Restore AI files created on a newly created database? by following below steps- 1. Backup the database at a cut off time, take a copy to server B 2. Enable AI Image file in server A 3. Leave the current database in server A up and running as normal with AI files turned on 4. on Server B - run binary dump, load and rebuild the index 5. on Server B - on completion, shutdown database on server A, copy AI files to Server B, now is it possible to apply those AI files that have been created on to the newly created database? I've tried playing with the sports database, it throws lots of system error but those errors are not easy to understand. Any help on this will be appreciable.
