F
Florin Drule
Hello, Does anybody know if it is possible to add values to a picklist dynamically rather than predefined values on the new UI? From what I see, on the new UI the picklists are not built using the tag, but instead of this, the are used inside a . Also, each picklist has a related field containing all the predefined values, which is not displayed on the screen and when changing this option, the values from the list are changed as well. I have eventually managed to dynamically fill a picklist values using jquery, but the issue is that I cannot change the picklist selected value. Please let me know if you encountered this kind of issue or if you know another solution to dinamically fill a picklist with values (using some KENDO UI functions for example). Thank you in advance. Best regards, Florin
