[Progress Communities] [Progress OpenEdge ABL] Forum Post: ABLUnit - Regression or not ?
  • Thread starter Thread starter Riverside Software
Riverside Software
Up to 12.1, failure to compile a unit test resulted in a job failure: test1: [ABLUnit] Could not locate element 'isTue' in class 'OpenEdge.Core.Assert'. (12927) [ABLUnit] QUIT statement found BUILD FAILED Since 12.2, this is not the case anymore, there's just a line in the log output: test1: [ABLUnit] Unable to build type info for C:\Users\gquer\projets\pct\testbox\ABLUnit\test8\src\ABLUnitTest.cls: Could not locate element 'isTue' in class 'OpenEdge.Core.Assert'. (12927) [ABLUnit] QUIT statement found [ABLUnit] Total tests run: 0, Failures: 0, Errors: 0 BUILD SUCCESSFUL I'd consider that a potential problem, as I suspect that almost nobody read the output of the unit tests (that's usually buried in a very long log file). Was that done on purpose ? Or is it an unintended side effect ?
