[Progress Communities] [Progress OpenEdge ABL] Comment on Speed up automated testing in Azure DevOps Build
  • Thread starter Thread starter James Arsenault
James Arsenault
For 6.0.2 we're looking at adding support for corticonManagement allowing testing against a running Corticon server and allowing wildcards for .ert selection. Testing against a remote server will allow you to build and deploy to a test server from your CI/CD scripts and then run ruletests against it without the overhead of deployment. Allowing wildcards on the -test argument will allow multiple ruletests to be run in-process with the overhead of only 1 deployment
